RedNigel
0
OK, bear with me and tell me if I am crazy
Last spring when I had to replace my rear PR3 at 7700 miles, it probably had some life left in it. The thing that put me over the edge was a 1MM strip around the entire tire and slightly offset to left of center that was worn ( or ripped) down to the cords.
I replaced the Michelin with a BT023 that soon developed the same 1MM strip in the exact same place. (queer, huh?)
After many visual inspections that never gave me anything to blame on the bike, this afternoon I finally saw something that maybe could be the culprit...maybe
Where the swing arm begins...right where the driveshaft housing begins and the swing arm crosses the bike...approximately in the middle of the swing arm, there is a small hole. Something was wedged into that hole and protruding from it. I am guessing a small rock. When I dislodged the object it fell into the swing arm.
I can't say for sure, but I think it may have lined up with the 1MM groove on the tire.
The only problem I have with this theory is that the swing arm is a long way from the tire.
The pebble was only sticking out maybe a 16th or 8th of an inch at best
Is it possible that at speed the center of the tire expands enough to come within an 8th of an inch of the swingarm?????
The only way I will know if I am right is if the groove in the tire wears itself out as the miles go by
I just don't see how two tires from two makers could have the same problem
