Igo
I'm going to see alot of 500 mile days. I'm probably going to have to go the 2 inch risers. I can be fine as I am but I'll have to get off the bike every 120 miles or so.
I know but I'd like to be able to go that 200 miles if I needed to.Shoot, Igo, you'll have to get off the bike every 200 miles or so, no matter what you do. You will be running out of gas if you try to go beyond that.
I changed my 1 inch risers to the 1.2 to get even more pull back on my NT. I just clear the tanks and my levers are as far forward as can go. It is MUCH better but I still have problems after a long ride. I'm going to try to foot position things as it is a habit for me to place the edge of my heel on the pegs. I think Rick and I are just alike in this respect.I had the shoulder symptoms with the stock bars and decided that the problem was actually the angle of my hands. Rotating the bars towards me, put the grips at a far better angle, but then they hit the tank at full lock. The 1" risers let me rotate the bars without having them hit the tank. I have them rotated down and back as far as possible without fouling on the tank. And then the brake and clutch levers rotated down as much as possible on the bars. Much better wrist position. No more shoulder trouble.
If your lower back hurts and you think it's from forward lean, try moving your feet back on the pegs. It makes the forward lean much more natural and comfortable. If you are hooking your heels on the pegs, it is harder on your back.
I think also that you are absolutely right Phil. To some degree, probably a rather large degree, we are using mustles that we haven't used before. They will strengthen and we will acclimate to the new riding form. I remember distinctly that this happened for me on my last bike.I hope it works out for you. Back early in my history with the bike, when I did my SS1K, I struggled with that pain between my shoulder blades. But I haven't felt that close to 9 months now. Our bodies adapt ... usually ... sometimes.
Now that looks interesting. Thanks for that link. What does the piece that extends over the brake lever do? How long ago did you buy it? In other words, would that adapter be available now maybe?I have a Tak Lok. Same concept as the BrakeAway. A little less expensive, but still made in USA. I think it looks more streamlined and it operates more smoothly than my BrakeAway did. The smallest adapter wasn't quite small enough for the NT, but I think I ended up wrapping a piece of double-sided exterior use tape around the attachment spot, and it's been just fine. The VP of marketing offered to send me the proper size adapter once they get one manufactured. I don't know if heated grips are an issue for it or not (I don't have any). I think it would be worth contacting them to find out. I'm really happy with mine!
http://www.takonix.com/
I am in the Madison area. If you’re a hockey fan I would think you’re happy about the Bulldogs. Me I am a Sioux fan and not happy that they could not pull it together last week.Hi Joe,
Where in WI do you live? I'm about as far north as you can get and still be in the State? Just got my NT700 last week and am enjoying very much.
