gazzzwp
Hi all
This is not a serious problem but nonetheless one I would like to solve. There is some hesitation around 2500rpm to 3000rpm that feels like an HT or fuelling problem.
When accelerating even very lightly the problem is hardly noticeable. To notice it you have to virtually hold the revs constant at the flat spot and then you feel the hesitation. As soon as a minute amount of power is applied the problem goes.
Otherwise it's fine through the rev range from low down below 2500rpm to cruising at 5000rpm or higher.
Quite puzzled about this. She's done 6100 miles, and is 3 years old. The plugs were changed last year at 5000 miles. The air filter has not been changed and I plan to do it next year. In my experience this tends not to make a huge difference to the engine but I'm open to suggestions.
I have sprayed the plug tops and HT leads in case there is some leakage. No trace of HT leakage anywhere and I would have thought that this would have given problems through the entire rev range.
There it is guys - open to suggestions please.
G
G
