For really good expresso coffee on the go I use Handpresso it just needs hot water.
I even take it to work with me.
wow - WOW - that is excellent design . bravo, You don't see design like that every day - 'simplicity' yet sophistication. Oh Mr. Honda ^^^ can we have this idea built into the frame of a MC ? Perhaps regenerative braking to pump the pressure, btu's from waste engine heat and a napkin dispenser on a ball mount - oops - overdid it again. Thanks JQL that surely is the bomb..For really good expresso coffee on the go I use Handpresso it just needs hot water.
Alex, The bags I have from Twisted Throttle are the Dry-Spec combo set (http://www.twistedthrottle.com/twisted-throttle-dryspectm-d66-waterproof-motorcycle-dry-bag-modular-packing-system). They call it the D-66, and it has both the D-38 and the D-28 bags. The D-38 has a plastic liner that helps it keep its shape when it's not completely full and a roll-top closure. It's pretty huge. I carry my cot, my sleeping bag and pad, my Kermit chair, my tent lantern, and assorted other small stuff in it and could still cram more little odd-shaped things in.Will have to get the tent online as well as the sleeping bag. I am sure that Phil will let me know how many and which bags I need to get from TT. I am really looking forward to doing Spearfish this summer.
Charlie, I need the airmattress with the cot, too, but the Big Agnes insulated Q-core pad works well for me and packs smaller than the bigger air mattresses I've had. It helps me that the Luxury Lite cot gets me up about 6" higher than I would be with just a sleeping pad, but that may not be much higher than I'd be on a good air mattress.I have tried sleeping on cots many times andalways have to add an air mattress.
PhilAll this stuff goes in to my Dry-Spec D-66 modular waterproof b
Eldon, these pix were taken with the Half Dome 2+, but the Half Dome 4 is only an inch bigger in diameter and an inch longer package. You wouldn't be able to tell the difference just by looking.Are these pictures with the 1/2 dome 4 packed away in them?
I use them too. But when I have a long cylindrical package that sits perpendicular to the seat I find that just using the grab rails is insufficient. I end up using the hardware on the underside of the topbox rackI use the grab rails for tie downs all the time
