IMPORTANT NOTICE: Anyone wishing to perform this conversion. Jump directly to Post #65 and work your way backwards from there for what bulbs to purchase and the Installation Procedure
Hello All,
I just finished converting the headlight on NaTalie into a LED Headlight over the weekend. Please take a few moments to review the pictures of this process, Flickr Album - HONDA NT700V LED Headlight Conversion.
A few teaser pictures:
Here's a parts list for this conversion for under $30:
• Infitary H7 LED Headlight Bulbs Hi/Lo beam Auto headlamp, 6500K 8000LM
• Auxbeam Rubber Housing Seal Cap Dust Cover Headlight for LED Conversion Kit, Pack of 2 (70MM)
I would rank this conversion on a difficulty scale for 1 to 10, 10 being the most difficult. This project would be a 9 to 9.5 as the removal of the headlight assembly is required and requires all the bodywork to be removed to get to the headlight assembly and then remove it. Also, the LED Bulbs require modification to be able to fit into the headlight assembly, the link to the online album will show all the required modifications as a breif overview. Removal of the aluminum heatsink material is required in the shown areas. Removal of the OEM dust covers from the OEM cable assembly is a must in order to connect the wiring as shown in the provided images.
The entire process took me about 3 hours to complete as I had to figure things out as I went along. I am quite pleased with how everything came out and with the looks of everything.
I have not had a chance to see if the headlight height requires adjustment or how bright it is after dark. In the dark garage, everything looks great. In the daylight, the brightness is considerable more noticeable on both beams.
Disclaimer:
This process is not recommended for a Novice to perform or those shy around tools. A skilled person with some mechanical knowledge could perform this process with minimal issues as I have already figured out most of the difficult aspects of this process.
Let me know if any of you have any questions regarding this process.
The future is so bright that I have to wear shades.
Hello All,
Disclaimer:
