I replaced my drain plug with a Fumoto valve that way I can change the oil on the road without tools. I start off on the sidestand and then climb aboard and hold the bike upright with my legs for about five minutes and let it drain a bit more. To change the filter I put the bike on the center stand. I tighten it hand tight so I can remove it by hand. I just dump three quarts of oil in and I'm done. A slight over/unde fill will cause no harm.1Q) The manual says that NT will take 2.8L of engine oil if the oil filter is also replaced.
I have 3 bottles of 945ml oil, so fill 3 bottles is 2.835L, i am assuming an extra 35ml of oil should not cause any issues.. thoughts ...
i hate to throw away oil due to the environmental pollution angle...
ALSO: keep the bike on center stand when draining the engine oil. I did it on the side stand (assuming the tilt would drain out more oil), but when I put on center stand couple of more ml of oil dripped out.
But, for the transmission fluid, the side stand it better to drain, as when I put on side stand few more ml of fluid came out. Filling should be on center stand.
