That's for sure! I added up the price of the farkles already installed and it was a major factor in buying that particular bike. It would have cost me over $3000 to buy it myself.
Frosty's looks betterHere ya' go Joe! More farkle heaven!
SW-Motech Outfits The Triumph Tiger 900
The Triumph Tiger 900 is an all-new design, and SW-Motech has introduced a full line of luggage, protection, and other accessories to fully customize it.www.rideapart.com
They are made for Triumph by Givi (Trekker 46 l and 33 l). Triumph sells them cheaper :unsure:. The stripes are just reflective tape that I added. Rolls are available on Amazon. The cases came with a cheap stick on side reflector. The tape on the highest part of the side is helpful if you happen to put the bike on it's side for some reason. Peel the old off and put new on.Those cases definitely originally came from Givi. My top case is a clone of your left side case minus the stripes.
I thought they were exactly the same with the exception of the stamped name. I was wrong! The Givi rep said that he thought there was a minor difference in the mounting. I was at the dealer today and asked to try their Givi case. It is identical except the latching notch is about 1/2" lower.Those cases definitely originally came from Givi. My top case is a clone of your left side case minus the stripes.
Thanks, Will be good to see you in Spearfish and hear more about it.I put 4,800 miles on the bike since new at the end of Jul. Total ave mileage is 50.4 MPG. I can't think of anything that I would do differently. The bike worked great on the trip to S Utah. The custom seat helps. The longest day was 400+ warm and windy miles from Montpelier, ID to Moab UT. It was a long day, but the bike was solid. I don't know if the motor is as smooth as I expected from a 3 cylinder. They fooled with the firing order to increase torque. It does have great torque throughout rpm, downshifting not required. Center stand is not an option for the LHR. I installed a center stand from the standard model option. It takes some effort to put it up, but much easier to service the chain and check tire. My old Garmin GPS has a TPMS, so I screwed the sensors on the 90 degree OEM metal tire stems.
I bought a BT OBD II gizmo that let me reset the Service reminder with my Android tablet. I prefer fresh oil in the bike during Winter rest. The dealer will still do the required checks.
Looking forward to riding it to Spearfish next year.
Good idea for home. With my boots on, I can get it up on the center stand, but I have to unload the bike before putting it up. While traveling, I put it up on the center stand to service chain or check the tire. I also put it on the center stand and cover at night when on the road. There is no reasonable way to shorten that center stand.Frosty - My NC700X is lowered but I still have a standard centerstand from the S-model. I made a simple helper by using about a 4" x 12" piece of plywood that I place in front of the rear tire then roll the bike onto the plywood. Now, it's much easier to get the bike up on the centerstand!
Maybe you can cut off and re-weld the tabs at the bottom, that touch the ground... might be good for an inch and not mess with the rest of the contact points.Thanks Tosh, that could work for me since the bottom of the left case is 10" wide. I do like to load the bike on the centerstand.
The centerstand for the Tiger 900GT was too big of a challenge to shorten. I think the Tiger 900GT centerstand was a shortened version of the taller factory 900 Rally. They share the same frame but a longer suspension (?)
To take a small section above the cross bar and keep the pin distance/ alignment the same would be difficult. There may be clearance issues as well. The plywood is definitely easier.
For the NT700, there was some speculation that using the centerstand when operating the panniers reduced latch problems. Other than a spring becoming detached, I never had any problems with mine. (I also opened the latch when I closed them and gave some final pressure to feel the click.)
Phil was there when the owner of Empire Cycles just gave an NT700 pannier a slam. I may have been a little quick to mention not to do that.
